speed transducer
speed transducer
hi guys!!
anyone who is familiar with SPEED TRANSDUCER made by RHEINTACHO(GERMANY)?? the device is used to measure the speed of the deisel engine as overspeed protection. I suppose you folks had encounter this device about troubleshooting..
i got this kind of case:
1.)whenever we engage the barring gear that is turning the crankshaft, this device pick up or sensed the rotation of the plywheel, that is not for its intended activation.. it only activates(device) whenever the speed is about 100 rpm..
could anyone point out the problem?(we already replace new tachogenerator).
please give an excerpt of the device if any is available..
thanks in advance!!
thanks in advance!!
RE: speed transducer
http://www.autoshop101.com/forms/h36.pdf
for: Different principles
http://www.dynaproducts.com/pdf/techpdf/f-23721.pdf
for: Magnetic pickup construction
