Add Text Fonts to Drafting Work Bench in V5R12
I'd like to ad Fonts to my drafting work bench. I only have 2 Fonts if I create a new drawing sheet (SSS1 and ROM3.) I read in one drawing from the Badencorp Advanced training companion disk and it is loaded with them (Fonts I mean). I'm running V5R12 on Windows XP Pro.
RE: Add Text Fonts to Drafting Work Bench in V5R12
Read again, you should find information like that :
Available font for a drawing is defined by the standard of the file, (and the font available on the computer).
When you create a new file, catia get the standard (with or without Fonts) and put it in the file.
When you open a file, the standard of the file is read and then you have (or not) fonts.
Find information about drawing standard, catia admin, XML file...
Eric N.
catiav5@softhome.net
