max distance from AP to antenna wireless
Hi all
I would like to know what is the maximum distance I can install the patch antennas from the Access point in an outdoor installation. I am planing to use 6 dbi gain antenna and to install the AP as far as I can (if possible over 60').
I know there should be a restriction for signal strenght at the Access point side but I don't have that information.
Is there any additional parameter that I should take into consideration for this not usual installation?.
I appreciate any help in this regard
RE: max distance from AP to antenna wireless
As for what to watch out for:
1)If you are using externally mounted antennas, keep the cable runs as short as possible. Line loss is much greater at the higher frequencies most WLAN systems operate at. Try mounting the access point as close tot he antenna location as possible.
2)Ensure you have a good path between your antennas. Mount them high enough that you will not get intermittent obstructions from passing traffic (pedestrian or vehicular).
3)The greater the distance apart, the more important it is to point the antennas accurately. Remember close enough only counts in horseshoes and hand grenades.
4)Enact all security precautions available on your WLAN system. Do not rely upon the default settings to get you by. You probably do not want someone snooping around on your network.
