Moisture separator for Vacuum Pump
I am currently designing a vacuum fixture for aluminum aerospace parts. I am concerned that coolant (CNC machining) will return to the vacuum inlet. I would like to seprate the moisture from the return air. Is there any recommendations for an external, inlet filter? The pump being used is Rietschle VACFOX.
drosero@rogers.com
drosero@rogers.com
RE: Moisture separator for Vacuum Pump
Jeff
Jeff
