Raw field gas
Raw field gas
Can anyone help with UK/European companies specialising in the supply of equipment to clean up raw offshore field gas to suitable specs for gas turbine operation.
I know this will largely depend on the gas specs as it comes from the well, and each field will be different. This is just a general question at the moment.
Remote control of this equipment would be a decided advantage.
Thanks.
Ron
Thanks.
Ron
RE: Raw field gas
When it comes to gas quality visit the www.solartronmobrey.com site and follow the links to the 3098 relative density analyser. This is used for gas blending instrumentation and i understand has been used to good effect in helping Large Caterpillar engines optimise their performance when operating of different gas fuel sources. (You may need to consult the Canadian Caterpillar dealer for this or Westech in Canada.)
JMW
www.viscoanalyser.com
Eng-Tips: Pro bono publico, by engineers, for engineers.
