Changing the size of the font when printing from the port
Hi, I'm trying to change the size of the font when i send the information to the printer, my code is:
where "Puerto" is the printer port, (LPT1, mapped to a network printer), and what i'm looking for is for a common command to tell the printer to make the font condensed.
I won't use the printer object, because it is to slow, even i know that with that object i can use Printer.fontSize=10, or something like that. Printing from the port is fast, and for my application, i need to print fast, so, if you know if exists a common command to tell every printer (there will be 44 dot-matrix printers, and maybe differents) or if there is another way to print fast and changing the size of the font, please let me know
Thanks in advance
CODE
Open Puerto For Output As #fNum
If Err = 0 Then
Print #fNum, strCadena
If bClosePortAfterPrint Then Close #fNum
End If
If Err = 0 Then
End If
Thanks in advance
RE: Changing the size of the font when printing from the port
