Question about draft on surfaces
I'm asking this for a buddy of mine.
He's new to UG (NX) and is having problems drafting surfaces. As far as he knows, he can only select a plane or an edge as the neutral reference for the drafting angle. He wants to know if it's possible to select a surface as the neutral reference.
Can anyone give us some help?
RE: Question about draft on surfaces
NX2 has got more options to draft and can draft from a parting surface I suppose.
Even if it lets you pick a surface as a reference, I advise against that. I doubt that it is possible unless the surface is planar because it would not specify a vector (use the u direction? v direction? surface normal? - at what point on the surface?). The datum axis gives you control; just be sure that it is ordered before the tapers (create it before the tapers or simply reorder it in the feature list).
Sorry I can't answer your question However I understand exactly what you want. I.e controlling rib thickness where joining to main surface is important to avoid sinkmarks in plastics.
In Catia v4 & V5 you can pich a neutral surface or even a skin of surfaces(v4) as a neutral plane and then simply define your draft direction by line or plane.
I would be surprised and dissappointed if UG doesn't have that capability since it's regarded as a far better solid system than Catia v4.
