Looking for a liquid or brine to be liquid at -120 ¦C
For a experiment I need a brine or liquid to be liquid at 120 °C .
Liquid gas , as air , oxigen or nitrogen is out of reach.
Maybe a combustion gas as propane or butane.
Of course safety is a concern , but it will be under good safety conditions.
Pardal
RE: Looking for a liquid or brine to be liquid at -120 ¦C
You can find in any chemical manual a plethora of liquids (organic and inorganic compounds) boiling above 120oC at atmospheric pressure.
Safety, price, availability, corrosion, heat transfer capabilities, etc., etc., are considerations that may influence your selection.
It is -120°C
Minus 120 degree centigrade.
Pardal
metyl cyclohexane -127/+101
2-methyl pentane -154/+60
pentane -130/+36
propyl alcohol -126/+97
For thermostatic baths one can also use:
isopentane -159/+28
allyl chloride -134/+45
allyl alcohol -129/+97
Again the preferred liquid would depend on a series of factors as mentioned above.
I am curious..
You did not answer 25362"s first post.. "Whats the purpose of the experiment (he said exercise)?"
My question is; if a material commonly used as a coolant such as liquid nitrogen is out of the question what is the chance that the coolants (refrigerants) suggested in "25362" second post will also out of the question. If you are in a location where the availability of some commodities are scarce, then you have a real problem.
I am aware that LN2 can be hard to come by in some countries but it still can be obtained.
What I see is your willingness to use very dangerous materials to perform a single experiment.
The cost of LN2 could be much less than the safety precautions necessary to protect the operators using other volatile materials.
Your post is very cryptic and therefore does not explain alot. I think there are people who monitor this forum who could help you achieve your goal if you would provide a little more information and thus create some interest in your cause.
I wish you well
pennpoint
The intention is to have a "energy" acumulated while runing a smal refrigeartion device , so when needed I can tranfer this energy in a short time.
The final product shall not have any consumible cost as Liquid Nitrogen.
It is because it is buy with a no retornable credit fund , so the only cost it is electrical power , that is shared on the building so no one will take care of it.
It is a incredible argument , but it so how it work here.
The propyl alcohol -126/+97 seem to be the best suited.
Where I can get the specific heat of liquid and the viscocity at such temperature near its melting point?
Please apologize me for not to give a wider explanation.
Hope you can help me.
Pardal
My concern is it's specific heat as liquid .
Do you know where I can find it??
Thanks for the past and post help.
Pardal
Go to these sites:
MSDS
www.jtbaker.com/msds/englishhtml/p6390.htm
Specific Heats at various temps. www.basf.de/basf/img/produkte/loesemittel/e/n-Propanol_e.pdf
Good Luck
pennpoint
