concrete strength
concrete strength
concrete strength
Has any one experianced a recorded crushing srength from a cube of belowe strength at 28 days if the the specefication of concrete strenth was C35 and the recorded slump taken on site was between 75 and 100
RE: concrete strength
Yes.
However, this does not sound the death knell for your structure.  The acceptance of concrete is calculated on a statistical basis.  If you read your design code there will be an acceptable level of cube failures.  You need to record ALL of the cube results you have ( there is a minimum number of results required to make a valid population).  You then undertake a statistical analysis based on the mean plus or minus a set number of standard deviations.  This will then tell you the number of results which can fall below a given strength level.
Andy Machon
