strange flat pattern problem.
I have a sheet metal part, I unsuppress the flat pattern in the browser and it shows me the flat pattern.
When making a drawing of this part,I put flat pattern as the view and it shows it as folded.
in the browser for the drawing view I have
"orientation" : flat pattern
"reference configuration" : default
"flat pattern options" : DefaultSM-FLAT-PATTERN
under the "More Properties" button
"configuration information"
"use named configuration" is checked and the name is "DefaultSM-FLAT-PATTERN"
Any ideas?
Any ideas?
RE: strange flat pattern problem.
Thanks.
rocheey, I renamed the flat pattern config exactly as the default flat pattern is named and it worked fine.
