Strange Pulping Equipment
I am new to working in pulp mills and I am wondering about what the purposes of fiberlizers and mix pots are?
In the mill I am working in, it looks like the use the mix pots as line splitters.
The fiberlizers are on the discharge of the blow tanks in the pulp mill.
I have done web searches for both of those items and have had no luck.
Can someone point me in the right direction?
RE: Strange Pulping Equipment
IIRC, the fiberlizers are used to reduce cooked but intact chips to fiber and to break up fiber bundles.  Most likely a rotary device similar to a refiner.
HTH
Jack
Jack M. Kleinfeld, P.E.  Kleinfeld Technical Services, Inc.
Infrared Thermography, Finite Element Analysis, Process Engineering
www.KleinfeldTechnical.com
