Spline by pole?
Spline by pole?
Spline by pole?
In the Catia r5v12 sketcher, can you put in splines by poles, rather than by point?  and can you constrain, or at least edit the spline ends to match curvature, rather than tangency?
I know I saw a curvature comb(porcupine) toggle too...
RE: Spline by pole?
Hello Gunman,
if You double click the spline in sketcher the spline edit window opens and You are able to set both curvature and tangency.
Regards TPale
RE: Spline by pole?
Spline in Sketches are defined by points only, to create curve by Poles you need FFS licence.
Eric N.
catiav5@softhome.net
