Function block prog. in Pascal
Dear Fellows,
 Can any body let me know the web address or other stuff from where I can learn programming the function blocks in pascal for S7.
I have a problem in understanding a command
temp:=DWORD_TO_REAL(db20.dbd0)
how it works.
Bye,
Umar Zia
RE: Function block prog. in Pascal
Hello, mumarzia;
I only saw your post today, ans I hoope this answer will still be usefull.
Siemens' Pascal-like language is called SCL, and you can find the SCL programming manual at this address:
http://www4.ad.siemens.de/-snm-0135030360-1084460314-0000003309-0000000211-1087584982-enm-WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=5581793
The instruiction you are looking at is a Typecast function; the value in DB20.DBD0 is a DWORD format, which you convert to a REAL (IEEE floating-point value) before loading it to the variable "temp" (which presumably has been declared as a REAL value).
Hope this helps,
Daniel Chartier
