Luer-Lock dimensions and drawing
Hello everybody.
I'm trying to find the "Male" of S.S. Luer-Lock tube connector (quick turn tube fitting) , I am designing some medical instrument and I need the standard dims. of Luer-Lock.
(if you search for Luer-Lock) in mcmaster (http://www.mcmaster.com/) you'll see which connector I'm looking for.
Michael
Michael
RE: Luer-Lock dimensions and drawing
ISO 594-2:1998
"Conical Fittings with a 6% (Luer) Taper for Syringes, Needles, and Certain other Medical Equipment"
Part 2: Lock Fittings
Price$58.00
Luer taper is 6 degree if I remember right. You can do a web search and get some of the other dimensions from suppliers. Also, if I remember right there may be some subtle difference between plastic and metal luers.
Jim
alvramon
