ASME B31.3
3
ASME B31.3
ASME B31.3
Could you please advise on where in the UK I could purchase a copy of ASME B31.3 Many thanks
RE: ASME B31.3
I'd go to www.asme.org There's ordering information right on the site. I believe the new edition is coming out this summer, so unless you need it urgently, you may wish to wait.
RE: ASME B31.3
You might also want to pick up a copy of Dr. Charles Becht's book on using the B31.3 Code - it is an ASME publication.  Also, Glynn Woods wrote a book on B31.3 that is published by CASTI Publishing.
Regards, John.
RE: ASME B31.3
Try PE Publishing, the publishing arm of the Institution of Mechanical Engineers
