Help 1HP Electric Motor
I have a cable winch that I would like to drive with a 1 HP electric motor.
I would like to Run Motor Forward and Reverse.
Don't know how to do this... Have a Dayton 1hp Electric motor. Instruction say to Switch Switch T5 and T8:
Forward: (P1) (P2-T8-T3) (T2-T5-T4)
Reverse: (P1) (P2-T5-T3) (T2-T8-T4)
Would like to Run motor forward and Reverse for winch.
By the use of UP / Down Button From old winch. has 2 hots and one nutrual.
Any sugestions?? Are other motors better for this prodject?
RE: Help 1HP Electric Motor
Visit
http://www.allaboutcircuits.com/vol_4/chpt_6/4.html
for wiring diagram of contactor and push button operated motor.
For a winch so I don't want it to stay on..
Is it easy to Wire?
Voltage also determines how it shall be connected!
110v is a 4 wire control.
220v is 3.
The 2BW44 can be converted to momentary too!
see...
http://www.grainger.com/Grainger/productdetail.jsp?ItemKey=2BW44
Take note... make sure that the drum switch OPENS both hot legs, when off, to the motor when considering it for 220vac or you may need another disconnect before the switch!
Careful with using AC motors on winch/crane applications, they produce very low torque when at zero speed -- when you release the brake you might find your winch drops the load. . .
For that reason cranes usually use either DC motors or, for AC motors, VFD's that can provide both high-torque and precise speed control at zero speed.
You might want to post some details on the mechanical side of your winch to be on the safe side.
Please keep in mind that I'm speaking way out of my area of expertise here, too. . . .
There is a potentially serious safety aspect to electrically reversible 1ø-motor application similar to the type described.
With regard to reversing 1ø-motor rotation, be certain that if the start winding is switched integral to the 1ø motor [with something like a centrifugal-start switch] that motor power is interrupted long enough the permit the centrifugal-start switch to reclose, or else the motor rotation will likely not reverse, but unexpectedly reaccelerate and continue to rotate in the previous direction.
