type MPCV Network Protection relay
Familiar with this relay?
If so, it states if the Watt-Var switch is "ON".
It will indicate a balanced 3-phase tripping under reverse magnetizing current and at the same time handle phase unbalanced condition.
Will this see a line to ground fault?
Thanks for the help...............
