SW2004 Crashes on closing files
We are running two (SW Certified)Dell Precision Workstation 360 2.4 GHz One GB RAM with SW2004 SP3 and an  ATI,Fire GL X1, 128MB video card. Each station was crashing 2 - 4 times a day. We replaced the video card in one station with a NVIDIA FX1000 and the crashing was reduced to once a day. We always crash when we are closing a file. We are running floating licenses and the license administrator is on one of workstations. Any suggestions or is a crash a day "goodness" with SW.
RE: SW2004 Crashes on closing files
We have similair machines. We have crashes more or less dependent on the "weight" of the files.  The heavier the weight the more likely the crash.
I have isolated our problem to the Wildcat card and I will be trying an NVIDIA 3000.
To answer your question - one crash a day would be a blessing for us when we are on the heavy assemblies.
jackboot
This was sent to me by my VAR:
See if these settings help you...it helped me
Suggested memory settings for SolidWorks
Amount of RAM    Suggested minimum/optimal virtual memory setting
64Mb    192Mb min / 256Mb optimal
128Mb    384Mb min / 512Mb optimal
256Mb    768Mb min / 1,024Mb optimal
512Mb    1,536Mb min / 2,048Mb optimal
1.0Gb    3,072Mb min / 4,096Mb optimal
Have you installed the latest approved graphics drivers & switched the driver setting to "SolidWorks"?
from (the City of) Barrie, Ontario.
If you choke a smurf,   what color does it turn?
