Swapping blocks and keeping attributes
We're trying to update our titleblocks on all of our drawings, but I want this to be an automated process in carrying over the existing attributes from the old block to the new.  I understand that the fields in both blocks need to be the same, but is there a lisp routine (or even an existing command) that I can run to replace the old block with the new & maintain all attribute info?
Any help would be appreciated.
Chris Bobrowski
RE: Swapping blocks and keeping attributes
Use pp_SetAttsAsDottedPairs to get the original values into a list and then use pp_XchgAttsFromDottedPairs to set those values in the new titleblock.
;pp_SetAttsAsDottedPairs:
;Arguments:    <Entity name: 400e1978>
;Returns:    (("DATE" . "20020304")("TITLE" . "some drawing"))
;Dependencies:    pp_GetEntVal
(defun pp_SetAttsAsDottedPairs (BLKWATTS / ALIST ATTAG ATTTXT MORE TBNEXT
                                TITLENT)
  (setq    MORE T
        TITLENT (entnext BLKWATTS))
  (while MORE
    (setq TBNEXT (entget TITLENT))
    (cond ((= (pp_EntVal TBNEXT 0) "ATTRIB")
           (setq ATTAG     (pp_GetEntVal TBNEXT 2)
                 ATTTXT     (pp_GetEntVal TBNEXT 1)
                 ALIST (append (list (cons ATTAG ATTTXT))ALIST)
                 TITLENT (entnext TITLENT))
      ) ;cond1
      ((= (pp_GetEntVal TBNEXT 0) "SEQEND") (setq MORE NIL))
      (t (setq TITLEENT (entnext TITLEENT)))
      ) ;cond
    ) ;while
  ALIST
  ) ;defun
;pp_XchgAttsFromDottedPairs: Looks for matching tags and sets string in block
;Arguments:    <Entity name: 400e1978> (("DATE" . "20020304")("TITLE" . "drwng"))
;Returns:
;Dependencies:    pp_GetEntVal, pp_AttMod
(defun pp_XchgAttsFromDottedPairs (BLKWATTS ALIST / ATTAG ATTTXT INLIST
                                   MORE TBNEXT TITLENT)
  (setq    MORE T
  (while MORE
    (cond ((= (pp_GetEntVal TBNEXT 0) "ATTRIB")
           (if (setq INLIST (assoc ATTAG ALIST)) ;make sure tag exists
                (pp_AttMod TBNEXT (cdr INLIST))
             ) ;if
      ) ;cond1
      ) ;cond
    ) ;while
  (command "REGEN") ;For on screen updating
  ) ;defun
;pp_AttMod
(defun pp_AttMod (E ATT)
  (setq E (subst (cons 1 ATT) (assoc 1 E) E))
  (entmod E)
  (entupd E)
;pp_GetEntVal
(defun pp_GetEntVal (E NUM)
  (cdr (assoc NUM E))
;pp_SetEntVal
(defun pp_SetEntVal (E TAG NEWVAL)
  (setq E (subst (cons TAG NEWVAL) (assoc TAG E) E))
  (entmod E)
  (entupd E)
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
BU,
Thank you for this, however I am a complete newbie when it comes to LISP (outside of dragging the lisp function to the AutoCAD window!) :)  How would I be able to set this up such that I can pick the first block, then pick the second block to add the attribute data?  Also, from what little I know, where are 'BLKWATTS' & 'ALIST ' defined?
Again, any help (and patience) would be appreciated.
C
