Masonry Block
3
Masonry Block
Masonry Block
There is a formula to height of masonry block wall, ratio of Block width dimension; i.e. 4" block, maximum 6' height. I've forgotten the formula and can't find note within my reference materials for maximum height of 6",8", 12".  Can you help?
RE: Masonry Block
What code are you using?
RE: Masonry Block
The used to be a limit on the height of masonry.  I believe the limit was h/20.
Undfer the "new" masonry codes, that provision was basically removed.  However, most people still use it.
RE: Masonry Block
Should have included: International 2000, but I haven't found anyone who can interpret masonry codes from that format.
RE: Masonry Block
Well it references ACI530-99 and it does not have a specific h/t for engineered design of masonry walls. There are h/r equations that take into account the slenderness of the wall. However, there are h/t limitations for columns.
If you are really concerned about P-delta effects on the wall, you could try the UBC slender wall design method and see what you get, Enercalc has it.
RE: Masonry Block
THE EMPIRICAL DESIGN PROVISIONS OF ACI 530-02 HAVE THE h/T PROVISIONS. TABLE 5.5.1
THEY ARE VERY USEFUL AS A GUIDEINE EVEN FOR ENGINEERED DESIGNS
RE: Masonry Block
You're going to be pretty limited by the emperical h/t values. For an 8" block, you are only allowed to go to 12' high for partially filled units in a bearing wall.
RE: Masonry Block
Although not req'd by ACI, I would probably limit h/t to about 25.
RE: Masonry Block
The "old" NCMA Masonry Code (circa 1970,now longer referenced), limited the height of unreinforced load bearing masonry walls to a h/t ratio of 20.  (8" block limited to 13'-4").  Columns where limited to an h/t ratio of 25, based on the least dimension...minimun dimension for a column was also 12".
Reinforced masonry walls under the NCMA Code were limited to h/t of 36, unless "evidence by a qulaified person showing the wall met all the other requirements".
As I previously ststed, the MJSC no longer limits the height of the "engineered" walls.  Walls are designed based on the h/r ratio, where r is the radius of gyration = sq. root of (I/A).
If you are "designing" a masonry walls based on the EMPIRICAL DESIGN methodilogy of Chapter 5, the h/t ratiuoa are still used.  The h/t ratios are different than the "old" NCMA limits but not significantly.  The "new" h't ratios classify the walls as bearing or non-bearing walls, interior or exterior.
RE: Masonry Block
There is a book called "Masonry Design Manual" whose 2nd addition was published around 1972.  On the first page of the first chapter it gives a table for maximum ratio of unsupported height to thickness.  For reinforced hollow unit masonry bearing walls, it give h/t of 25.  It also gives h/t ratios for nonbearing walls for combinations of exterior/interior and reinforced/unreinforced.  Apparently this table comes out of the 1970 UBC.
It is interesting that they give and h/t ratio of 20 for an unreinforced nonbearing exterior wall.  If you were to engineer a wall like this, particularly with a small dead load to reduce the tension bending stresses, it would never work out under most wind loadings.
RE: Masonry Block
Thank you. It has been several years since I've dealt with masonry partitions and didn't have a comfort level with the new codes.  Apparently, same people that write the tax code wrote revisions for the building code.
RE: Masonry Block
be careful how you apply those h/t ratios they are different according to bearing/non-bearing, exterior/interior. Forget the empirical stuff you can get much better values by using the engineered approach.
