infrared survey priorities
Hi Guys,
I’m starting an electrical power distribution infrared survey on a huge (4 million sq ft) convention center. I have to set priorities to get the most out of the time and budget allowed. I am thinking of this order. Please let me know if your experience would lead you to a different order. (My scope is secondary of 12.47 kv/480 volt supply transformers out).
Thanks.
277-volt lighting breaker panels. (90% of lighting is 277 volt)
480-volt breaker panels to house load transformers.
HVAC motor starters
Cooking equipment breaker panels.
480-volt switch boards (800 amp and above)
120-volt house receptacles breaker panels
VFD’s
Motors (bearings)
Thanks.
HVAC motor starters
VFD’s
Motors (bearings)
RE: infrared survey priorities
Budget-wise, I would start on the major switchboards, switchgear and transformers - the stuff that will shut down the largest blocks of load if it fails. Feeder circuits for lighting are important for life safety. For panelboards where you can't readily load branch circuits, check for loose connections on the breaker terminals. That's a common problem.
The most important tip would be to have plenty of personnel on hand to facilitate access to the equipment and the connections to be scanned. In other words, the longer the IR technician has to wait for a panel to be located and opened, the less time he will have to scan. It is not unreasonable to have 4-5 electricians opening and closing equipment covers for each IR technician to maximize scanning. If the technician can just move quickly from one location to the next, where everything is ready to be scanned, you will be amazed at how much equipment can be scanned in one day.
Map all locations out and the easiest route between them, and open everything in each location before the technician gets there. It actually takes only seconds to IR a panel, but it will take 4-5 minutes to open and close it.
http://www.thomasregister.com
and type Cameras: Infrared under Product or Service, which will return 49 companies to approach to
