Definition of "pea rock" (or "pea gravel")?
Does anyone have an industry-standard gradation for either of these terms?
Thanks!
RE: Definition of "pea rock" (or "pea gravel")?
It's usually 1/4 to 3/8 inch gravel - but this can vary.
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora.  See FAQ158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
how about AASHTO M43 (ASTM D 448) No. 8 or 89 gravel
Typically No. 89 gradation (ASTM C33)
Dennis59
This is a city spec from Regina, Saskatchewan, Canada.
Pea Gravel*
Sieve Size      Percent Passing by Weight
12.5 mm            100%
10 mm            90 - 100%
5 mm             0  - 10%
2 mm             0  - 1%
* This material shall be clean naturally rounded aggregate.
The naturally rounded/nonfractured part can be important depending on the application (ie. naturally rounded stone should be used when pea gravel is being placed against a geomembrane or drain tile to eliminate puncturing).
Hope this helps.
