Time history analysis for bridges
Can anyone point me some instructions or links on how to perform a time history analysis for a vehicle crossing the bridge span.I need to Know which time functions are recommended for this case as well as the whole procedure.
It's a very special bridge.There's a 240m arch crossing over the bridge span from one side to de other, with a height over the road of 40m.From this arch 16 cables give intermediate support to the 180m span.
I'm using Robot millenium 14.2.
RE: Time history analysis for bridges
Please tell us what you're looking for and we should be able to better answer your question.
One of the professors at Clemson University is studying bridge testing and rating, and he probably has tons of info. Unfortunately I cannot recall his name at the moment, but if you contact the Civil Engineering Department at Clemson, I'm sure they can put you with him.
I'm interested on knowing if the passing of the vehicle causes a significant increase on the cable stays tension forces,or in the opposite side ,if it can totally unload the cable.The static analysis results showed me that cables are ok.
What I've done so far is :
I created several load cases with a single unity concentraded load.For each load case this unity load is applied 4m ahead of the previous load case, simulating the passing of a moving load, through the whole span.In the time history menu, I used tringular time functions associated with each of these loads.Then I tell the program when each of these load cases will act.Depending on which vehicle speed I want to simulate, I set each the loads to be applied on its correct time window,one after the other.
Then , comparing the bars internal forces from the time history analysis with those found on the static analysis(of these load cases),I know if there's an amplification factor or not.
If there is an amplification ,then I apply the factor only to the internal forces due to moving load case.
Is this correct?
I rather think you want and need the influence of the vehicle irrespective of speed. A moving load analysis. In other words where can I place the load to determine the most critical response to the element I am investigating.
How you set that up might be easy or difficult depending on how you've modelled the bridge or section thereof.
Based on your explanation I think this is what you're attempting but confusing it with the dynamic capabilities of the program. You should have three loads, simulating the three axles of the HS20 vehicle that are 14' apart. Move these three loads around to find the maximum response for the element you're looking for. Most programs have the capability to do this automatically for predetermined axles and or user defined axles.
I want now to analyse the dynamic bridge response to a moving load entering the span and crossing it at some speed.
What's the best method to do that and if what i've done is correct?
Also, I recommend that you check the websites of ASCE and FHWA. At the ASCE website you will be able to access the abstracts for the Structural Engineering and Bridge Engineering Journals. At the FHWA website you will be able to access the following libraries or databases: Transportation Research Board (TRB), National Highway Research Cooperative Program (NHCRP), and TRIS.
Once you have an actual time history you can read it into the program you are using or manually input the data. Please note that some commercial programs have serious limitations on the size of the time history that may be used. Run the analysis and evaluate the results. Keep in mind that the time history is very specific and should be combined with others to approximate the vehicle behavior. Any scaling of the time history should be checked in both the time and frequency domain for plausibility. In other words you can't just factor the data -- it is a mathematical representation and must make sense in either domain.
Good Luck!
Rafael
