robertson QL-deck
robertson QL-deck
Does anyone have information on Robertson QL-21-20 floor deck. I am checking a floor which was built in the late 60's, early 70's. I know that the deck is 3" deep with 2 1/2" concrete on top of that. I need to know the span ratings and the profile of this deck. Any help would be appreciated. Thanks.
RE: robertson QL-deck
My email is dwray@littleonline.com
Thanks.
http://www.icc-es.org/reports/pdf_files/ICBO-ES/2739.pdf
I also have some other catalogue information that I could fax you.
Just to let you know if this will be of any use towards your enquiry, check modern steel construction site via www.aisc.org and paste this up in the solutions section.
I will do the same from my end.
aileme (Structural)
