Designing a 315 MHz antenna on flexible substrate!!!
I am currently playing around with ideas on designing a antenna on a flexible substrate like a copper foil. One side is a polystyrene and the other is a 1 oz copper cladding.
I have tried a quarter wavelength patch antenna. Basically a square with a short 1.25 cm long feed point from the RF circuit to the patch. If the outside dimensions is a quarter wave than it will fit in my housing.
Anyone try a slot antenna or possibly a circular patch design? Please do not limit yourself to these ideas.
thanks
RE: Designing a 315 MHz antenna on flexible substrate!!!
You can try to dielectically load the patch.  You can add a dielectic over the patch or select a different substrate.
Check out Roger Corp.(http://www.rogerscorporation.com/acm/index.htm)
You can also dielectrically load the gap of the slot antenna.
