Black Anodizing 7075 Aluminum
We had 2 lot of parts sent out to be Black Anodized per MIL-A-8625, Type II, Class 2 with a thickness of .0002 to .0004 in. One lot was our tpical material for the part 6061-T651, the other lot the material was swithced to 7075-T651. We allow for 1/2 of the build-up per surface and the parts were measured before coating. When they came back they had less material than when they went out, O.D,'s undersized and I.D.'s oversized. The plater said the material switch was the cause but I don't understand why this should be.
Should there be any difference in the parts other than slight color change?
Thank you,
Bob
Thank you,
Bob
RE: Black Anodizing 7075 Aluminum
TTFN
