Any way to get multiple explodes from single configuration?
I have an assembly of many components installed into a box and it would be very helpful to show explodes in several assembly stages of the same configuration.  Is there any way to do it?
Tim
RE: Any way to get multiple explodes from single configuration?
You can make explodes from derived configurations.  Make derived configurations from the desired config and use those.
Due to illness, the part of The Tick will be played by... The Tick.
http://www.EsoxRepublic.com
That will work well for drawings, but I don't like the fact that I have to activate the config, then re-expand the tree... before I can activate the Exploded view in the assembly.
I see and ER coming up... I think.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
