Design table driving part instances
Hi all, it's me and my silly questions again.
I've got a part with different configurations (driven by a design table), and I'd like to insert several instances of the same in an assembly, each one with a different configuration. (by the way, something very easy to do with Sol****rks
If I insert the part once, and make a regular Copy/paste, each configuration change on one is reflected on the other. (that's not exactly what I wanted :o(
If a use Paste special the new instance can keep its configuration. Fine. But I then have to save it as a separate file (linked to the same table file) But I just can't have as many files as configurations (that's just what design tables were supposed to avoid!)
So far I keep going with the last "solution", but If there's a "prettier" way to do it please let me know.
Thanks!
Thanks!
RE: Design table driving part instances
If you are up to speed on PowerCopy and Catalogs, this is the route you might want to take. I would make a PowerCopy of the part and place it in a catalog. In the catalog, you can resolve the part families, which will give you a part document for each configuration. Then, you could insert the desired configuration from the catalog browser. At this stage, it becomes relatively painless and quick.
Now, what I just said here was simplified. You would first need to get to know how to develop a PowerCopy, which can take a while. Then, you'd need a crash course in catalogs. The key here is resolving part families.
Good luck!
This a quick way if you say have only a couple of configurations.
Now open your product and insert each unique part that you had saved off in the first step.
Puck, your're right. I've only got 5 configurations and creating 5 files is in this case the fastest way to go. You can also choose "user-friendly" names as you create them.
As for what you said, Arkangel (resolve the part families in the catalog) there's a nice example about it in the Online Help. It automaticaly generates a bunch of files from a table driven screw (or nut, I don't remember). It's not very difficult to do, but I won't use it unless I reach 10 configurations.
Both seem to show the same: you must have a part file for each configuration your want to use. I guess it's the "Catia way" to handle configurations. Why not? I just don't find it very elegant!
