Controller IC help
Controller IC help
Controller IC help
Im looking for an IC that i can run off of 5V DC from a microcontroller to control the on/off of components that will be using 12-24V DC to operate.  I was just going to use one transistor to control another transistor/scr but i know there are more "up-to-date" methods by using IC's.  Can anyone suggest an IC to do this?
Thanks in advance
RE: Controller IC help
run a google search for solid state relays...most of the major chip maufacturers have them (Maxim, Analog, TI, etc.)
Add Crydom to the list
"Never look down any at anybody, unless you are helping them up."
Jesse Jackson.
How much current do you need?
<nbucska@pcperipherals DOT com> subj: eng-tips
3-4 Amps
If you only need a few tens of ma, there are devices available.
However, for the higher current the easiest way is to use a logic-level input N-channel MOSFET, and switch ground to the item.  There are some available in dual surface-mount packages.
However, for external devices in some applications, ground switching is an unacceptable practice. Power switching is preferred which leads to an intermediate device to switch a P-channel MOSFET, or bootstrap supply arrangements still using an N-channel.
For 12 to 24 VDC, you might check for some semiconductor power devices designed for the automotive market.
Take a look at a "high-side switch". (search for that keyword)  This is what's used in automotive and at voltages up to 48 volts DC.  Several max currents are supported:  3, 5 amps.  International Rectifier and some others make such parts.  Most models can be triggerd by a logic signal, the integrate the MOSFET the control logic and protection circuits.  And they're cheap too.  I used it for a soft turn-on/turn-off circuit in an automotive application and it worked great.
Felix
You could go the old-fashioned route and use a simple 5V relay.  Also, check out Digikey (www.digikey.com).  They have a good selection for ALL of the solutions posted.  good luck!
Thanks for the help guys, especially you felix, im actually using wiper motors because i needed more current for my applications so the automotive option is a very useful one.
Thanks again to everyone who replied.
