Al heat shield
Al heat shield
Moved post:
I want to use an aluminum sheet as a heat shield. Standoff will be 2" from exhaust pipe. What material grade is typically used and with what surface finish (i.e. AA3003, mill finish)?
RE: Al heat shield
Do you need to machine the aluminium? or just shear and bend?
No load?
RE: Al heat shield
1. ~500 degrees F. Components in the same vicinity are less than this.
2. Shear to size; no bend and no machining.
3. Absolutely no load except its own weight.
Extra info. Will be predominantly used in coastal area (Florida).
RE: Al heat shield
RE: Al heat shield
(rnd2)
For corosion resistance you might want to go with the highest Al content. I think thats the 1xxx series...
Really though any thing you can get will be just fine.
nick
