Redneck Engineering Terminology
Being a yankee living in the south (yes, I know there's another 'name') I thought that a translation of southern engineering terms might be appropriate here. I've actually heard these.
Please add any that might help us all communicate - just include the translation. Who knows, maybe Jeff Foxworthy will be interested...
CONCENTRISICAL - 2 circles on the same center
OVALATED - Circle that becomes out of round
WALLERED OUT - When the fit becomes too loose
CRASSION - Rust or corrosion
Keep the wheels on the ground
Bob
showshine@aol.com
RE: Redneck Engineering Terminology
THATBIGAROUND - semi-quantitative dimensioning of a part in which the speaker makes a circle with his/her forefinger and thumb that corresponds to the object in question
YAY BIG/YAY LONG - semi-quantitative dimensioning of a part in which the speaker uses one or two of his/her hands to identify the size of the object in question
Cory
CADDY-WOMPUS - (adjective) description of an object that is not level, plumb, and generally lacking orientation with adjacent space-time.
Cory
As far as the length and width of something that's "yay big"--that would be (accompanied by appropriate hand gestures), "about Yie by Yie"....
http://hcs.harvard.edu/~golder/dialect/staticmaps/q_76.html
But in this dialect survey, they are claiming that for some people (.13%) kitty corner and kitty wampus mean the same thing, which is news to me. Can't find either of them in my American slang dictionary for some reason.
"Joistus"--Joists
"Sheeting"--Sheathing
True southerners will shorten caddy-wompus to caddy-womp.
rmw
gozinta - as in 2 gozinta 4 twice
and
halfagain - as in 3 is halfagain 2
CURVY CURVY - turn or bend, or multiple turns or bends in ductwork or piping.
DINGTWIZZLED - confused, upset, frustrated, and/or catty-wompus.
MASHBUTTON or MASHBUT - To press a button or other lever to activate appropriate device, such as a disconnect switch.
I think it is hafagin. There is no "l" nor "a" after the "g" in the word, if said correctly, maybe even haffagin. And, the more I roll it around in my mind, it is haffagiun. You definately have to have two syllables after the "g" to be a true redneck.
rmw
WELT - (welded)- "them 2 parts is WELT together"
Weldeddid - same meaning, different operator
Windup Scale - tape measure
See It - verb meaning sit - "Ya'll See It that part on the machine"
Bob
showshine@aol.com
Jesus is THE life,
Leonard
Bung
Life is non-linear...
gozinta - what water does through a guzzins, usually before it does the opposite through a guzzouts. In vehicle design, properly placing all the guzzins and guzzouts can take quite a lot of time.
-I
I work on vehicle design so I appreciate what you are saying, but it is amazing how many people don't.
At one of my early jobs I was assigned to work on underhood cooling and one of the managers took me aside to give me some pointers. Most important, he said, was to make sure you had a way to let the air out, you couldn't just let it in or your cooling would be poor. I learned that this was actually tested.
Actually tested? As in a wind tunnel, or as in caveat emptor?
David
Chicago bolt (n.)
1. A fictitious fastener (screw ot bolt) with a jog in the shank to allow the fastener to pass through misaligned holes
2. An undersized screw or bolt used when misalignment of holes does not permit use of the correct size screw or bolt
http://www.EsoxRepublic.com
The note on the dwg would be "Pound to fit, paint to match".
Another favourite expression, "don't force it - use a bigger hammer."
JMW
www.viscoanalyser.com
Eng-Tips: Pro bono publico, by engineers, for engineers.
Actually that last one is something that everyone should learn and employ. When I was working in a steam plant, it was frequently necessary to "persuade" massive objects into small movements. A small hammer would seldom allow the control needed (you would have to swing too hard to impart adequate force). A "bigger hammer" often was able to shift the object with a smaller proportion of the operators available strength and gave much better control.
Even in dumb-sounding sayings, there is sometimes a valid genesis.
David
Not dumb sounding at all; the description is accurate. I call all my hammers "persuasion devises". Of course, I call my wife "spousal unit".
Best regards,
Matthew Ian Loew
"I don't grow up. In me is the small child of my early days" -- M.C. Escher
It was secured by a 1.5" hex nut and rather than look for an adjustable spanner (Monkey-wrench?) he reached for a hammer.
"We call it an English spanner." he said with a wry grin.
JMW
RCH = Unit of measure. Very Small. R stands for Red. H stands for Hair. I'll let you figure out the C.
Southern Chrome = Duct Tape
In some parts of the South, that would be "...I was usin plars.
Jesus is THE life,
Leonard
I once worked in a production machining plant where lathes were turning rough forgings held on a mandrel, and which had several tools active in the work piece at a time. It was called rough turn. The tools, which were held in the tool holder by hex nuts on studs, had to be changed often, and the operators used hammers instead of wrenches to loosen and re tighten their tool holders. There weren't even any wrenches anywhere to be found at the work station.
I learned the technique from them, and often, to this day, prefer the use of a "persuasion device" instead of a wrench. I think I will go relate this story to my "spousal unit". (good one mloew)
rmw
rmw
(the pc on your desk)
Redneck Engineer exam
Try these acronyms out on your 'spousal unit':
W worship
O our
M master's
E every
N need
If we never hear from you again, we'll know you have tried it. I have too strong a sense of self-preservation to test it on my partner!!
If we learn from our mistakes,
I'm getting a great education!
'puter is what my grandaughter calls it. She is in speech therapy.
I failed every question that I tried on Redneck eng exam. does this mean I don't qualify or that I am a prime candidate.
Jesus is THE life,
Leonard
Exams don't mean much to rednecks anyway.
Mechanic at toolbox: Phillips or common?
Mechanic on the line: Ether one, I am going to as a hammer.
In Japan a Phillips screw driver is a "Plus Driver", and a straight screw driver is a "Minus Driver", used even if the rest of the discussion is in Japanese.
I showed your initialisms to my "spousal unit". HE thought they were real funny!
But, boy, is this thread off-topic! Should'nt a new one be started on "the best tool to use for any given job"
P.S, I vote for staplers and scissors as multi-purpose tools. The former makes a good hammer and the latter a good screw-driver and pliers.
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
MYTHOLOGY - Wayz ya'll do stuff (Methodology)
Bob
showshine@aol.com
Used that one on the wife!
Doc. says, no perminant damage to the left eye.
Need new glasses though.
Found another use for a cutting board!!!
Rerig.
(You can't cut me off...you don't know where I'm getting it!)
After watching Troy a couple of weeks ago I remembered the Millihelen, a unit we use to use in school as opposed to the 1 - 10 scale.
What is the "avoirdupois" equivalent?
http://www.hyperdictionary.com/dictionary/avoirdupois
http://www.fact-index.com/a/av/avoirdupois.html
JMW
The tick
It's the amount of beauty required to launch one ship.
(Helen of Troy being the emost beautiful woman in the world) caused a thousand to be launched.
http://www.hyperdictionary.com/computing/millihelen
Explain Queen Elizabeth the Second and her involvement in launching ships? The requirements have clearly changed!
An important function as the number of people who can be pursuaded to drink the stuff, despite PT Barnums famous adage, is insufficient to keep up with the supply.
I think they'd let anyone launch ships. In fact, it might be an idea to have group launchings, not one person launching a group of ships, but a group pf people (C list celebs) to launch each ship. Given the increased size of ships today, this is the only way to match the champagne consumption to the tonnage launched.
QEII obviously can't launch enough of them by herself.
JMW
TTFN
JMW
TTFN
Ain't you never heard of the poem and song "Ode To The Little brown Shack Out Back?" I think the poem is by Browning or Longfellow.
Jesus is THE life,
Leonard
What kind of expression is that to be using in the Language / Grammar Skill forum??
Avoirdupois
The avoirdupois system is a system of weights defining terms such as pound and ounce. It is the everyday system of weight used in the United States, and was used in the United Kingdom and elsewhere until metrication. It is considered more modern and standardised than the alternative troy or "apothecary" system.
Does this definition strike anyone as a mite odd. But then, I find folk refering to it as the Imperial system, dating back to George III. Even the UK finally agreed that the French were onto a good idea.
Jesus is THE life,
Leonard
We machine shafts on a LAY
Before we can use a hand drill we have to PLUG IT UP
When it gets dark suddenly we change the LAHT BUB
Manufacturing Freeware and Shareware
http://mrainey.freeservers.com
Here's some from the structural/civil realm...
Footer...usually a small footing for a residential wall. It's common pronunciation is more like "Foot-her".
Coluuuum...a vertical support in a building or bridge. The pronunciation is "Col-you-mmm.
I've heard of structural ironworkers dreadedly refer to using the "Monday". Or when all else fails in persuading drift pins and (forbid) bolts inbetween several plys of steel, they'll call for the "Monday".
The "Monday" is a monster of a "beater" or sledgehammer. While most typical sledges on a job are 8 pounders, the Monday is a whopping 12 pounder. The best I could figure is that long ago some ironworkers would forget things over the weekend and pick-up the Monday, thinking it was a typical 8 pounder only groan, under the added weight, "its gotta be Monday!".
Anyway, it doesn't sound like much more weight until you give it a go and remember most bolt points aren't oriented on a horizontal plane but a vertical one which means you're swinging sideways!
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
I call my hammers "spousal attitude adjusters". Now, where is that left-handed monkey wranch (sic) & wahr straightner (double sic)?
(snicker)
(duct tape for the educated)
JMW
Answer:
Yessir show can. R cain't say fshowr ef they can liveinm.
Mah't b ginst reguelayshons.
http://www.duckproducts.com/
Cory
True
PERTNEER - meaning about or approximately
Warren
Hg
High Tech Redneck
The first time I heard this phrase, I was pierced to the soul. But now, many years later, older and wiser, I proudly display the nom de plume on my hardhat.
~NiM
Yoyo - Air impact wrench used to tighten bolts in structural steel erection.
Rattle the bolts - Tighten the bolts.
Plumb Bob - When a crane hook is not being used and is just sitting.
"What happens to the human body when a safety harness is tested at great heights."
~NiM
"...in America they haven't used it for years..." or something like that...
Putting Human Factor Back in Engineering
I've always used "footing" as in "For stability, Joe better improve his footing". Yet, we use it as a noun - "Joe is designing footing no. 2"!? Crazy, but that's the way it's been used around the Midwest for as long as I've been in the business.
Footer, of course, is often pronounced foot-her, a very distinctive second syllable and more or less a good strong southern accent to it!
Qshake
Beater---actually ANY hammer. Usually a short (21") handled 8, 10 and, 12lbs. sledge.
Monday---16 or 20lb. beater often with short handle(20"-30")
Stob---ya stick it in the ground with a beater.
New York---to drive a missalligned bolt with a Monday.
Drive up---rattle up, tighten-from old rivet terminology.
Mesican speed ranch---adjustable spanner
Enfadoe---reverse direction or turn around.
Bullpen---large drift pin.
Burner---skilled with a cuttintorch.
hotwrench---what a burner uses.
That'le do for now.
Rod
RATCHAIR - On this spot - put thet thin RATCHAIR.
TINSINSTOW - I ama goin to the TINSINSTOW for a chaw ah tobaccay, y'all want sompin.
GETOUTAHEER - Go way
STAND AND CHAIR - Let me hear y'all STAND AND CHAIR for duh Citadel.
ALL - everyone - We be ALL here
ALL - A lubricant - Ah change mah ALL every tin tousand miles, mo or lest.
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
EARTIS or AIRTIS - as in "Here it is..." or "There it is..." You have to know the situation in order to understand the context (here or there).
~NiM
However---after a couple weeks, Ah'm tawkin jess the same. Reckon it's the hillbilly genetics takin over!
Rod
In SoCal I had a boss from S.C. We hated it when he went "home" to visit because it was three weeks before we could understand him again!
Hg
Ciao.
We done designed thet thar beam awallago. Dubya twayllve by twenny-six.
fixin' ta: "fixing to"
Weer fixin ta go home n havabeer. Yankees say, "Fixing to go home? What's broke? I don't understand."
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
Cory
I must disagree. I've known many redneck yankees, and many southern gentlemen (and gentlewomen) who are definitely not rednecks.
Slippery Hot: So hot that when you pick it up it slips out of your hand. Typically occurs after it's been welt or had the blue wrench put to it.
I was raised in the central portion of the cajun state, and was called a "yankee" by my coona__ friends all my life.
rmw
Good Luck
We had a secretary who was always 'fixin' to do things... one day I told her I was "..repairing to go to a meeting.."
I responded to her puzzled look with "Repair, fix... all the same. I'm just trying to fit in down here"
She was never 'fixin to' around me again!
Bob
Ciao.
Antigodlin-sort of like catter wampus ("that frame's got antigodlin and it chatters to beat he--!")
wrent-mangled or ripped ("drill bit caught it and wrent that setting all to h---")
(give it) all nine pounds-I am told this referres to a nine-pound hammer. Means hit it hard.
From head to feather-in all of the way, or a ways in("I had a long taper pin and run it in from head to feather.")
Fraction-breakage by trauma("drop that while it's too cold and there'll be fraction")
I have seldom if ever heard those terms outside of the old shop I used to work in.
>>Neighmond (Mechanical) Jan 23, 2005 From a long line of hill billies: Antigodlin-sort of like catter wampus <<
Bob
It's what we do to the open ends of fiberglass pipe insulation where it terminates, as in, "Pooky up them there ends with some of that there sealant." Southern sheetrock installers have been known to pooky-up joints in walls too...
Love this!!!
Old Dave
The antenna base needs a little pooky.
I need to pooky the panel after installation.
I have tried, in vein, to stop the shop slang.
But I won't let them use it when requesting assistance.
I guess that makes me anal. Too bad.
Now I have to go clean the pooky off of my hands.
From Montana,
Gas axe = acetylene torch
Yep = affermative
Hanging prepositions = I'm going to town, you want to go with?
"Ahr compressure"
Which I took to mean "air compressor". It wasn't just one instance, it was a whole 5 minute conversation with several people.
Gotta love living in redneck country!
~NiM
" To assemble 'Cadillac Converters'. These here fixtures hold sompthin so's they can add the gold, silver, platnum and other stuff. "
I guess if I drove a Cadillac, I'd want gold plated muffler bearings too....
Bob
That is how the receptionist paged people to answer the _ _ _ _ _ _ _ _ _ in a Bluefield WV manufacturing facility.
Finally we came near to a pear-center and/or by context it became clear that he meant power-center.
Now, does anyone know what they call wet, sloppy dirt? It has to be something other than mud.
Bofems = Both of them
Colyum = column, such as structural steel column
Footer = Footing
Sheer = Shear wall
Hedder = Header (slightly diffrent prunuskiation)
overheard yesterday:
"I got an idear...how's about ya'll foller me over yonder so's I kin carry my truck back?"
On local TV: "I sure hope we don't git no more tornaders around here"
...and don't forget to warsh your hands after you use the terlet....
Bob
Bray it
Belt it
Smack it
Twat it
All of which mean, of course, if it dunt fitit, itit.
Now I deduced he meant soldiers,his use of "bunch" as a colective, especially for a military unit, had me going.
Just how many collective nouns are there in Redneck?
I know just two:
"Bunch" as in the above example and "muss" as in: a "whole muss of wares" (a whole mess of wires e.g. when refering to the wiring loom in a car, sorry, pick-up)
I am not sure if a "six-pack" counts as a collective.
JMW
www.ViscoAnalyser.com
A six-pack qualifies as one of the four major food groups for any meal during the day.
Bob
Wm
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
"She's got a whole passel of young'uns running around the double wide"
Racing and bullfighting are the only real sports...everything else is just a game.
Bob
Hg
I'm guessing a Butt-load comes before a ****-load?
Rerig
Qshake
There are only two sorts of NASCAR fan:
1) Foul mouthed, drunken, shirtless tobacco-juice spitters,
and,
2) Their husbands.
Flame-Hammer = Oxy-Acetylene Torch
Stinger = Electrode Holder on an SMAW rig
Na Angledah is someone born in either Maine, New Hampshire, (forgive me mother) Vermont, Mass, Connecticut, or Rhode Island.
The Above are also Yankees and proud to be the ones that were brave enough to eat the first Labstah!
Flaming Wrench = Oxy-Acetylene Torch
Qshake
(micrometer)
unliahned (pronounced like 'un-lined')
refers to MISALIGNMENT!
~NiM
(from a recent email)
Nobody likes to particap I guess
Southern spelling creates an entire new language
"If A equals success, then the formula is: A = X + Y + Z, X is work. Y is play. Z is keep your mouth shut."
-- by Albert Einstein
For those of us north of the 49th, generally the most puzzling dialect to comprehend would be so-called 'Newfie' sayings. Newfoundlanders have their own, very distinct sayings, and they often compound the problem by talking incredibly fast (as compared to central and western Canada).
Nevertheless, I worked for several years with citizens of Newfoundland, and I found them to be some of the best-natured, fun-loving, and most extremely hospitable people I have ever worked with. If you ever have a chance to, I'd highly recommend a trip to Newfoundland or Labrador! Just sitting in the local bar and trying to understand conversations going on around you is challenging! (and if they find out you're from "away", it generally gets even more fun, as sometimes the entire bar will participate in testing your knowledge of local saying to date...)
Here's only a few Newfie-ism examples:
"she" or "Her" (pronounced 'er) - generally used to replace the word 'it', as in "How's she goin', eh?" (How are things with you), "Boy, she's gettin' nasty out there" (The weather is getting rough) or "Fiddle wit' 'er until she's right" (Keep adjusting it until it works properly)
"side by each" - beside one another, as in "Just put those there side-by-each, that'll do 'er."
"slippy" - slippery, as in "She's gettin mighty slippy out there, better watch 'er." (watch your footing, it's slippery outside)
"where y' to?" - Where are you right now?
"about" - doing, happening, see "B'ye"
"hold up" - Stop, hold on, desist, see "B'ye"
"B'ye" - 'Boy', general reference for someone else, as in "Hold up there, b'ye, let's see what yer about" (Stop what you're doing, I want to see what you're doing before you do any more)
"stay where yer to, b'ye, I'll come where yer at..." - (Don't move, I'll come over there [for whatever reason])
"Bass-ackwards" (or "arse-frontwise", "arse front") - backwards, all wrong, as in "See b'ye, ye've gone an' wired it all arse-frontwise" (you've wired it backwards)
Other places for some example Newfie-isms, including excerpts from the Newfie-English dictionary:
http://www.io.com/~sjohn/sandra/nfsay.htm
http://
Enjoy!
rmt131
to add an apostrophe "He get's it done"
Truck Driver: "Where'd ya want dis load?"
Clerk: "Dumpitdare" (say it really fast with an arm wave and emphatic finger pointing)
Translation: "Where do you need me to set this load down?" "Put it over in the area marked B-2. (DUMP-IT-THERE"
~NiM
"Don't forget, the meeting to meet the instructor for smoking cesession is tomorrow June 21st at 10:00 am. Please come and meet him."
I wonder what she is smoking.....
You must be REGISTRATED by Friday October 21
Playing Tech Support this morning over the phone with a service technician in Arkansas, "Are you sure the 10a fuse didn't blow after replacing the controller?"
Tech says, "Done been had that."
This is a term that means, "I have already tried/checked that." I can never seem to find the opprotune time to use that phrase.
OUTVERT: The elevation of the inside of the downhill end of a pipe or culvert, where the water flows out. Often used with INVERT.
My employer is based in Florida, I am in California. Because of the time difference, I take tech support calls once the Florida operation goes home. This entire thread describes my daily work life.
Sorta = absolutely
Kinda = almost
Kindasorta = I think so, can't remember
There 'bouts = close, but not sure
'bout chyahr = closer still
That'll do = meets specifications
Jes fahn = exceeds specifications, but I will not give you the satisfaction of knowing that.
Yessur = yes
Yessur = I understand the question, but I have no idea and I don't want you to know it
Nosur = I had no idea what you were even asking me.
Wahr = wire
Kaybull = cable (often, the 'u' is silent, especially in Texas)
Heet sank = heat sink (I have seen it spelled this way in several emails and faxes)
Huckedy-puck = Hockey Puck (a euphamism for ceramic style SCR electrical device)
Frahd = fried, as in the magic smoke came out
Uppun dahd awn me = It was working, but quit when I shoved that scewdriver into it.
Kaint = can't, or won't, no difference.
The worst thang ees?, afta 'bout 'n hour er 2 wif 'em on th' phone?, I starts ta talken lahk 'em too, and sumuvem gets ta thanken its down raht insulten. Kaint hep muself tho.
Eng-Tips: Help for your job, not for your homework Read FAQ731-376
How else is one to pronounce "cable"? (And before you get after the "TX" in "HgTX", I learned to talk north of the Mason-Dixon line and east of the Mississippi.)
From at least one of my inspectors:
Correct = I didn't know that.
Hg
Eng-Tips policies: FAQ731-376
Southern-ese 'verbal short hand' (otherwise known as Red Neck Engineering Terminology) for "done been there, already had that fun."
Completely understandable, and usable in normal deep south technical conversation, but you have to have been there to understand it.
rmw
I couldn't adequately translate the phonics of how Texans say cable. I used to deal a lot with an outfit named Houston Wire and Cable, and whenever any of them said the name of their company I would crack up. Houston was pronounced something like "HEws'n", Wire was in a drawl, like "whohr", and the Cable came out with a heavy accent on the "kAIy", with a truncated "bl". Still makes me chuckle. I bought so mych whohr from them on an emergency project once that they sent me a pair of Tony Loma's and a Stetson XXX Beaver (that's a hat for y'all who don't know). That's still my fall back Halloween costume, but here in the SF Bay Area, you have to be carefull about wearing that, it can attract the wrong kind of attention.
Your last sentence is open to all kinds of ambiguities.
rmw
Not to someone who's LIVED in San Francisco!
First, my son and I were talking with some friends one time and someone used the term "you guys." "Hey," said Son, "you're in South Carolina. The term is y'all."
The other is New Englanders' inability to pronounce "er" unless it isn't in the word. The guy on the woodworking show says he's going to install the "draws" as shown on the "drawering." Fortunately, even though I watch him several times a week, it ain't rubbed off on me yet.
BTW, Son's in grad school in MA. If you ever run into someone giving out y'all's like they grow on trees, that'd be him.
DB
deja moo: I've heard that BS before.
-When submarines are built by stacking hull rings one on top of the next, prior to being turned "shipwise" (so the boat is pointing forward, not up.
A.
I still can't think of any other way to say it.
Oh well.
Hg
System Pipe Specifications
With reference to B31.3, new specifications for system pipe have been adopted by the Warranty Department on 1 Apr 04. If the customer's pipe does not meet the following specifications, it may interfere with system operation or move the operating conditions away from those specified on the initial bid. In this case, the Warranty may be considered void and any failure will be the responsibility of the Customer.
1. All pipe shall be made of a long hole, encased by metal or plastic material concentric with the hole.
2. All pipe shall be hollow throughout the entire length.
3. Do not use holes of different length than the pipe.
4. All pipe is to be of the very best quality, perfectly tubular or pipular.
5. All acid proof pipe is to be made of acid proof metal.
6. The I.D. (inside diameter) of all pipe must not exceed the O.D. (outside diameter) or the hole may be on the outside of the pipe.
7. All pipe is to be supplied with nothing in the hole so that water, slurry or other process material can be put inside at a later date.
8. All pipe should be supplied without rust. This shall be applied at the job site by the Contractor, Fitter or Customer. Note: Some Vendors are now able to supply pre-rusted pipe. If available, this product will save a lot of time on the job site.
9. All pipe is to be cleaned free of any covering such as mud, tar, barnacles, or any form of manure before putting up, otherwise it will make lumps under the paint.
10. All pipe over 500ft (153m) in length should have the words "long pipe" clearly painted on each end, so the Contractor will know it is a long pipe.
11. Pipe over 2 miles (3.2km) in length must have the words "long pipe" painted in the middle, so the Contractor will not have to walk the entire length of the pipe to determine if it is a long pipe.
12. All pipe over 6" (152mm) in diameter shall have the words "large pipe" painted on it, so the Fitter will not mistake it for small pipe.
13. All pipe closers are to be open on one end.
14. All pipe fittings shall be made of the same stuff as the pipe.
15. No fittings are to be put on the pipe unless specified. Otherwise straight pipe will be crooked pipe.
16. When ordering 90 degree, 45 degree or other elbows, be sure to specify right hand or left hand or the pipe will end up going the wrong way.
17. Be sure to specify horizontal, vertical, uphill or downhill sloping pipe. If downhill pipe is used for going uphill, the water will flow in the wrong direction.
18. Fittings come bolted, welded, or screwed. Always use screwed. They are the best.
19. All threaded pipe couplings should have either right hand or left hand thread. Do not mix the threads or as the coupling is being screwed on one pipe, it is unscrewed from the other.
20. Flanges must be used on all non-threaded pipe connections.
21. Flanges must have bolt holes external to and separate from the big hole in the middle.
22. Fasteners are required to hold flanges together.
23. If flanges are to be blank or blind, the big hole in the middle must be filled with metal.
24. All metal flanges must be cast or forged of the very best quality iron metal, close grained, free from blow holes, lumps, cavities, pock marks, pin pricks, and warts, otherwise we can't use them.
25. Gaskets shall be used to fill in the space between flanges
26. Gaskets are to be made of metal, rubber, plastic, paper, or some kind of goop. Do not use cow or sheep manure, it cracks when it gets dry.
27. All bolts are to be screwed.
28. All bolts must have a head on one end and a nut on the other.
29. Bolts without heads are to be furnished as studs.
30. Studs without heads are to be screwed all over and have two nuts, which is standard.
31. Studs with three nuts shall not be used since they would be odd.
32. All nuts are to be furnished in sacks. Sacks must be whole and sound, with a minimum of two nuts per sack. Paper sacks will not be tolerated.
33. All piping shall be installed with valves.
34. All valves must have an opening on each end with a flapper in the middle which goes up and down or sideways when you turn the wheel or crank so that it will open or close. Otherwise the stuff in the pipe will run out of the ends.
35. Valves are to be furnished by the kind required as follows:
* Ball valves shall have a ball inside.
* Gate valves shall have a gate inside.
* Globe valves shall have a globe inside.
* Check valves shall have a check inside. Czech's shall be in the Czech Republic.
* Angle valves shall have an angle inside.
* Plug valves shall have a plug inside.
* Diaphragm valves shall have a diaphragm inside.
36. Ball valves are not to be used anywhere with a female connection.
37. Diaphragm valves shall only be used with a female connection.
38. All completed pipe lines must go somewhere and connect to something. The Fitter and Contractor shall verify this prior to turnover.
39. Specify that the correct specifications are specified on all specific pipe specification documents.
Bi reet - it will be alright
"Give a man a hammer and the whole world becomes his nail" Dennis Mori 2005
Teach him to surf the web and he'll leave you alone for months...
Set him on fire and he'll be warm for the rest of his life.
http://www.answers.com/cable&r=67
Not so much redneck words but site slang:
OUT OF WHACK = misaligned
DONGER = site shed
POP IT = drill it
SMOKO = morning tea
CHIPPY = carpenter
SPARKY = electrician
STEELIE = steelfixer
SCAFFY = scaffolder
BRICKIE = bricklayer
DOGGIE = dogman/ crane chaser
ZAPPY = welder/ boilermaker
SLUMPY = concreter
SLOPPY = painter
NIPPER = site shed cleaner
ENGO or ENGY (pronounced en-joe or en-jee) = engineer
TREE-HUGGER = environmental engineer or any other environmental profession
ACCO = accident
TRUCKWITS (as in f***wits) = arrogant/ dangerous truck drivers
ALIMAK (brand) = builders hoist
enjoy
"I'm fixin' to fix all ya'll's tea"
Means: did you eat?
And the reply could be: yawnto?
Means: do you want to?
1. intoit - past tense of installing one object in another (refering to a replacement engine in the pickup.."I put a motor intoit"
2. cork - caulk .. as in wooden boats. "Ah corked the hull"
DB
I don't get the big deal. It's the same as the difference between "you people" and "all of you". Both are plural. One is exhaustive in its reference, the other is not. Wow, that sure gives me giggle fits.
Hg
DB
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
Thanks for the interpretation blackwed
New one for the main topic.... Fellow just moved here and the real estate agent told his wife:
"It won't take you long to get antiquated with the area"
South of the Mason Dixon Line: Y'all
Pittsburgh Area: Y'inz
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail."
Wm. Phelps Eno, ca. 1928
The Texasism that has knocked me for the biggest loop so far is "oil" pronounced to rhyme with "hole". Even weirder when it's "oily" pronounced to rhyme with "holy". Somehow I just wasn't expecting it.
Weird thing about the conservation of R is that it's often "conserved" within the dialect. So pahking the cah in the illegal arear is a wicked bad idear. (There's actually a perfectly normal and unfunny linguistic explanation for this pattern but I'll spare y'all.)
Hg
"He's out hunting fer air heads".
It took me about a week to figure out she was trying to say "arrow heads".
LOG ON: Making a wood stove hotter.
LOG OFF: Don't add no more wood.
MONITOR: Keeping an eye on the wood stove.
DOWNLOAD: Gettin' the farwood off the truck
MEGA HERTZ: When yer not keerful gettin' the farwood
FLOPPY DISC: Whatcha git from tryin to carry too much farwood
RAM: That thing tha splits the farwood
HARD DRIVE: Gettin' home in the winter time
PROMPT: What the mail ain't in the winter time
WINDOWS: What to shut when it's cold outside
SCREEN: What to shut when it's black fly season
BYTE: What them dang flies do
CHIP: Munchies fer the TV
MICRO CHIP: What's in the bottom of the munchie bag
MODEM: Whatcha did to the hay fields
DOT MATRIX: Old Dan Matrix's wife
LAP TOP: Where the kitty sleeps
KEYBOARD: Where ya hang the dang truck keys
SOFTWARE: Them dang plastic forks and knives
MOUSE: What eats the grain in the barn
MOUSE PAD: That's hippie talk fer the mouse hole
MAIN FRAME: Holds up the barn roof
ENTER: Northerner talk fer "c'mon in, y'all"
RANDOM ACCESS MEMORY: When ya can't 'member what ya paid fer the rifle
A.
ht
Start each day with a smile. Get it over with.
Cheers
Greg Locock
I read in the paper Sunday that a conversion error caused the crash of a Nasser Space craft last year so it is not just machinists who make mistakes.
Nasser?? Maybe that's what it will be called when NASCAR starts racing in outer space....
http://w
PS: Am I the only one who caught that? Does it show my age?
Norm
Great Idea! They could convert the sloped sides of the pyramids into grandstand seating, use the Sphynx for victory lane, probably not have to worry about rain... and race in the sand just like the original Daytona 500!
You and sprintcar must have been at the wacky baccy...
but don't you think the Mayan pyramids with their stepped sides are a much better design for a grandstand? Those sloping Egyptian ones could lead to all kinds of lawsuits when people slip off! You could have a South American jungle race at Chichen Itza!
I don't suffer from insanity. I enjoy it...
Last week one of the newly hired engineers told me he was doing some
Measurementation
ScottyUK - a Jungle race?? That would really get the tree-huggers up in arms if someone proposed clearing the forest for a race.
Besides - how would all the redneck fans get there??
I guess they had to wear bathing suits?
The lady behind the counter pointed and said: "Go the the lot and turn left."
Alertly, I said: "What?"
She repeated louder this time: "GO TO THE LOT AND TURN LEFT!"
Politely I asked: "Excuse me, can you repeat that just one more time?"
Impatiently she replied: "JUST GO'ON OUT TO THE LOT AND TURN LEFT!!"
Sheepishly I asked: "So... is there a parking lot of there or something?
Her reponse: "No, a TRAFFIC lot."
It was then that I knew I was in for loads of fun in this strange place that I now call home.
Very recently, I sought directions from a native of _far_ "upstate New York". Furriners would describe the area as 'rural'.
His reply began, emphasis added, "Turn left _before_ the building that _used_to_be_called_ ..."
Mike Halloran
Pembroke Pines, FL, USA
When I commented about this to the cashier, this elderly lady informed me that I should spend more time reading the bible. She pulled out her bible and showed me right where it said that
"three wise men came from a far...."
(For those not fluent in southern, "far" = fire)
Pete
yours
Reminds me of one of the guys in my shop when I ran a business outside of Atlanta Ga.
He came in late one morning apologising because he and his wife had stayed up late doing "fixins" for a barbeque they were having after work. Then he says "fixin them taters las night gev me a heyud ache. I gotta find me some peels." So I asked him why he had come to the shop looking for peelings, that he must have had enough of those with the potatoes. No he says "Peels fur m heyud ache. the kind ya swaller."
B.E.
6 engineers in a car (me driving) on our way to a conference in Alabama north of Huntsville (pronounced Huntsvull BTW). Get to an intersection in a small town and the map shows our route going straight, which we can see becoming a 2 lane residential street. A big green sign on the right side however says our route number and destination as being a right turn, and we can see that main road going east (instead of north) for as far as visible. We take the map route anyway thinking that the sign was attempting to route us through a gauntlet of fast food restaurants or something.
The road however quickly gets down to one lane and large dirt patches, so we decide maybe the sign is right. We go back and travel that way for 10 miles, but that road is now down to one lane as well, without any further reference to our route number, destination etc.
After a voice vote, we decide to swallow our manly essence and ask directions, so we go back to the intersection because there was a gas station there. We tell the attendant our destination and he confirms that the map was correct, it's down that little dinky road "a spell". I point out to the guy that there is a sign across the street saying the route goes to the right. He says (as phonetically as I can get it);
"Yessir, thaits raht, but don' pay no nevermahnd t' them there sahns, theys wrong!"
Where I come from eether one is correct, or is it ither.
(either)
"Ya'll drive down yonder fer a few miles then turn left right where Smitty's gas station used to was..."
Unobtainium: Material that is so costly, you cain't find it.
FUBAR: F**ked Up Beyond All Repair (ARMY, Ft. Hood Tx)
Taar's: Them round rubber things on yer wheel rims.
And yes, there be rednecks this far north.
Yanceman
They sounded every bit like I did, except for the pronounciation of place names ... and Allen-Bradley. They pronounced it Ailin' Badly.
Apologies to AB employees.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Yes it is. But you have got to hear them say it.
I say it, and people get offended. They say it, and it's an souther accent thing.
Albert Einstein
I think the local pronuciation of Georgia is Jaw-Ja
with the J pronounced hard as in Jaw breaker.
B.E.
Albert Einstein
Albert Einstein
The SAE technical term for rate of ground speed, enjoys wide spread use in the general population, as in,
Ah musta bin doin' bout 100 maul nar when dat tar blew out.
Dan
When you visit a Zoo in the north, in front of each enclosure is a sign containing the name of the animal, its scientific name, habitat and a description.
When you visit a Zoo in the south, the sign in front of the cage also includes a recipe......
That is hilarious.
Albert Einstein
Hg
Several years ago I took my (now) wife to one of those wildlife places (in Illinois) where they take in and look after birds with broken beaks, rats with sore feet, etc. There was an excellent booklet describing what to do if you hit a deer with your car.
We were expecting to read about road-side care, mouth-mouth, vets, fosterring of young, that sort of thing. But the whole leaflet was devoted to the legalities of who owns the body (if other vehicles were involved), where to take it to be butchered and whether or not you could sell the meat.
Amazing, such a different world!
Chris
Systems Analyst, I.S.
SolidWorks Pro 06/PDMWorks 06
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
metalergical
Someone must have been "huecked on foniks"
(for those outside the USA - "Hooked on Phonics" is an educational spelling and speech program for young children heavily advertised on TV)
In the UK "phonics" as a teaching method, was pretty much discredited, so I had thought, so I was surprised, on the plane back from the US a couple of years back to be sat next to some guy grumbling about not being able to upgrade (so he had to sit next to me). He relaxed a bit and said he was coming to the UK to do some TV selling of his "Phonics" "educational" toy.... I don't think he apreciated me telling him my impressions (which have to be easily as mis-informed as most of the population here so right or wrong, I felt he needed to up his market research).
Anyway, he unbent enough to invite my wife and I along to the QVC studio in London and out for a meal afterwards.
I guess, on reflection, that his marketing was probably fine... TV sales must be the ultimate for impulse buying... switch of brain, hit the mute button and reach for the phone and credit card... I'd guess he did OK.
JMW
Phonics by it self is insufficient.
When I see a new word, I try to pronounce it phonetically.
Whe I try to spell a new word, I also do it phonetically.
It's a tool.
Albert Einstein
Someone miss-spelled the name of the street.
It is "Bob Wor"
Never heard a Redneck pronounce the word "Wire" correctly.
Actually, I don't think you can spell the pronunciation of the word...it is a cross between "War" and "Were".
Anyhow, enough about Bob Wor.
By the way...for those of you not in the know.
"Bob Wor Fence" - to keep in/out the Cattle.
Rerig (Dallas-Ft. Worth)
ADT is working on the Fire Alarm system today, and it will be in test mode all day.
If you see a fire, please call 911, as the ADT system will not work.
This is the same company where I had to point out that there were no fire extingushers anywhere near the kitchen and the closest one was behind 2 separate locked doors in the lab.
Call 911?? Maybe from my cell phone as I'm heading home!
A copy of the notice was posted at every location that was required by code to have a fire alarm pull station.
yours
what city? - "dam it, texas"
sorry you feel that way about texas, but what city? - "no, dam it, texas."
after a few times of hearing this, i was confused and asked the fellow to spell the city name:
"D i m m i t t", Texas.
enjoyed the postings here!
-pmover
The were passing through the small town of MEXIA.
They stopped in a fast food restraint for lunch and asked the lady behind the counter how she would pronounce the name of this place. "And please say it slowly" they asked. (Knowing Mexican names sometimes aren't pronounced as the spelling would suggest)
Very slowly and with purpose, she said "BERR GERR KING".
P.S. The town name is pronounced "MU 'HAY UH" (go figure)
P.P.S. I once asked a phone Operator for the name of a company in El Conejo. I knew it was not pronounced as I was about to ask, but with no "tilde" over the "N" I wasn't sure.
I'll bet she is still laughing about the redneck that asked for El Cone-E-Jo.
Rerig (Engineer - not a linguist, not a redneck - don't own a Pickup Truck)
Albert Einstein
Ya'll come by now, ya hear?
thread1010-155528
