VBS problem
VBS problem
Hello everybody,
I'm facing at the moment a small problem with VBS. I'm writing data from WinCC towards a SQL Server, that part works but with retrieving this data I got a problem.
I send a date to a Table in an SQL Server
WinCC (datatype) Tex tag 8 bit character set
SQL (datatype) Smalldatetime
For the code see below
[COLOR=red]strSQL = "INSERT INTO BHI_Measuring_Station (Production_Date) Values ('" & Int(CDate(V15)) &"');"[/COLOR]
This part works, now I would like to retrieve this data and I use the following code.
[ladder]V1 = HMIRuntime.Tags("Balenumber_man").Read
Dim objConnection
Dim strConnectionString
Dim strSQL
Dim objCommand
Dim rsData
strConnectionString = "Provider=MSDASQL;DSN=CLaSS_Production;UID=sa;PWD=siemens;database=CLaSS"
[COLOR=red]strSQL = "Select Production_Date from BHI_Measuring_Station where Balenumber = '" & V1 & "';" [/COLOR]
Set objConnection = CreateObject("ADODB.Connection")
objConnection.ConnectionString = strConnectionString
objConnection.Open
Set rsData = CreateObject("ADODB.Recordset")
rsData.Open strSQL,objConnection
If Not rsData.EOF Then
rsData.MoveFirst
V3 = rsData.Fields(0).Value
MsgBox (V3)
Else
MsgBox("Baalnummer bestaat nog niet")
V3 = ""
End If
MsgBox ("OK1") 'HMIRuntime.Tags("Production_Date"))
[COLOR=red]HMIRuntime.Tags("Production_Date").Write V3[/COLOR]
MsgBox (V3) 'HMIRuntime.Tags("Production_Date"))
objConnection.Close
rsData.close
Set objConnection = Nothing
Set rsData = Nothing
MsgBox ("OK3") 'HMIRuntime.Tags("Production_Date"))
End Sub[/ladder]
The Producion_Date is red and U can see it in V3 but it doesn't show anything in HMIRuntime.Tags("Production_Date")
Is there something wrong with
Anyone?
Dim objConnection
Dim strSQL
Dim objCommand
Dim rsData
objConnection.Open
rsData.MoveFirst
MsgBox (V3)
Else
V3 = ""
End If
objConnection.Close
rsData.close
End Sub[/ladder]
Anyone?
RE: VBS problem
I'm sure you've figured this out now but just in case ...
You should explicitly convert V3 (which contains your date) to a string for the WinCC .Write function to accept it.
For example:
HMIRuntime.Tags("Production_Date").Write CStr(V3)
Hope this helps
Salma
RE: VBS problem
I didn't solve the problem yet, I really tried everything. I even tried Int(Cdate(V3)) and it was so obvious.
RE: VBS problem
I've got one small thing left to ask you if you don't mind?
I'm trying to make a Hardcopy of the screen. I know there is a special function for it but I would like to put it behind a button. I think that's possible but do you know the code in VBS?
Thanks in advance Rudi
