parameters when starting Catia
I've been lurking here and found out that there are some optional parameters to use when starting a Catia session (-env, -object, etc).
Is there somewhere a full list of all optional parameters?
I use V5R12 on W2k.
Steph.
RE: parameters when starting Catia
Thx.
I suspect this is not a full option list.
Steph.
I also think so, but I didn't find others. Anyway, these are most common settings.
I found also another file but I don't know if these can help you.
Here it is the contents:
!   DASSAULT SYSTEMES  -  V5 ENVIRONMENT FILE
! MODE : Global
! TYPE : Interactif
CATInstallPath=C:\Program Files\Dassault Systemes\B11\intel_a
CATDLLPath=C:\Program Files\Dassault Systemes\B11\intel_a\code\bin
CATICPath=C:\Program Files\Dassault Systemes\B11\intel_a\code\productIC
CATCommandPath=C:\Program Files\Dassault Systemes\B11\intel_a\code\command
CATDictionaryPath=C:\Program Files\Dassault Systemes\B11\intel_a\code\dictionary
CATDocView=C:\Program Files\Dassault Systemes\B11\intel_a\doc
CATReffilesPath=C:\Program Files\Dassault Systemes\B11\intel_a\reffiles
CATFontPath=C:\Program Files\Dassault Systemes\B11\intel_a\resources\fonts
CATGalaxyPath=C:\Program Files\Dassault Systemes\B11\intel_a\resources\galaxy
CATGraphicPath=C:\Program Files\Dassault Systemes\B11\intel_a\resources\graphic;C:\Program Files\Dassault Systemes\B11\intel_a\resources\graphic\icons;C:\Program Files\Dassault Systemes\B11\intel_a\resources\graphic\figures;C:\Program Files\Dassault Systemes\B11\intel_a\resources\graphic\splashscreens;C:\Program Files\Dassault Systemes\B11\intel_a\resources\graphic\symbols;C:\Program Files\Dassault Systemes\B11\intel_a\resources\graphic\textures
CATMsgCatalogPath=C:\Program Files\Dassault Systemes\B11\intel_a\resources\msgcatalog
CATFeatureCatalogPath=C:\Program Files\Dassault Systemes\B11\intel_a\resources\featurecatalog
CATDefaultCollectionStandard=C:\Program Files\Dassault Systemes\B11\intel_a\resources\standard
CATStartupPath=C:\Program Files\Dassault Systemes\B11\intel_a\startup
CATW3ResourcesPath=C:\Program Files\Dassault Systemes\B11\intel_a\docs
CATReferenceSettingPath=
CATUserSettingPath=C:\Documents and Settings\All Users\Application Data\DassaultSystemes\CATSettings11
CATCollectionStandard=
CATTemp=CSIDL_LOCAL_APPDATA\DassaultSystemes\CATTemp
CATMetasearchPath=DSKEY_TMPDIR
CATW3PublishPath=DSKEY_TMPDIR
CATSharedWorkbookPath=DSKEY_TMPDIR
CATErrorLog=CSIDL_LOCAL_APPDATA\DassaultSystemes\CATTemp\error.log
CATReport=CSIDL_LOCAL_APPDATA\DassaultSystemes\CATReport
CATDisciplinePath=
USER_HOME=CSIDL_PERSONAL
DB2INSTANCE=%DB2INSTANCE%
TNS_ADMIN=%TNS_ADMIN%
ORACLE_HOME=%ORACLE_HOME%
ORA_NLS33=%ORA_NLS33%
JAVA_HOME=
CLASSPATH_JDBC=
CLASSPATH=%JAVA_HOME%\classes;%JAVA_HOME%\lib\rt.jar;%JAVA_HOME%\lib\i18n.jar;%JAVA_HOME%\lib\classes.zip;%CLASSPATH_JDBC%;%CLASSPATH%
PATH=C:\Program Files\Dassault Systemes\B11\intel_a\code\bin;C:\Program Files\Dassault Systemes\B11\intel_a\code\command;%JAVA_HOME%\bin;%PATH%
Fernando
