PanelBoard KAIC
PanelBoard KAIC
A 480Y/277V, 3P4W, 35KAIC SC fully rated panelboard applied at 208/120V has a KAIC rating of? Thanks in advance for the input.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: PanelBoard KAIC
RE: PanelBoard KAIC
///Normally, 480V, 35kAIC SC panel may be requested to be replaced by 208V panel with required kAIC rating for the particular power distribution location having determined kAIC by software calculations, for example. However, the 480V panel manufacturer may provide its 208V short circuit rating. The figure may be the same, e.g. 35kAIC, since buses do not have stronger bracing for higher kAIC than 35kAIC.\\\
