Fastening a steel pipe to a wood pile cap
What fastening methods could be used to secure a timber pile cap to a 10.75" diameter 3/8" wall steel pipe? The application is the replacement of creosote wood pilings with steel pilings. Since NOAA will not allow timber pilings, I must use steel or concrete. Appreciate any suggestions.
RE: Fastening a steel pipe to a wood pile cap
You have creosoted pilings in place for a dock and they ahve detreiotated to where they need to be replaced? You have to use steel or concrete to replace them?
At the top of the new steel or concrete piling you want to have an untreated timber cap? You want methods to fasten the timber on top of the steel or concrete?
How close is any of this?
Tom
Alex Camerino
