GUI interface
GUI interface
GUI interface
hi to all... i did a gui using a monitor 1024x768 when i view it on a higther resolution monitor it appears orrible ..... everything is moved what should i fix?
thanks
RE: GUI interface
In a figure, you can set the coordinates you use to position gui items to be either pixels, characters or a fraction of the screen dimesions. If you use the latter then you may have fewer problems. Alternatively, write a number of different GUIs for the most common screen size, then query what the true screen size is to select which version of the gui to use.
M
Dr Michael F Platten
