VOC vs. Vapor Molecular Weight??
If I have a brew of hydrocarbons (eg. mixture w/ aliphatic diesters)
that has a published VOC of 7.813 lb/gal,
is there any way to guess a molecular weight of the vapor??
(vapor pressure = .200mmHg @ 68F)
RE: VOC vs. Vapor Molecular Weight??
Only you can be more sure based on the chemical process originating the VOC.
