Translation from Pro-e
What would be the best file format of translating files from pro-e to SE15?  The IGES files are a mess and the pro-e direct translator has missing features on occasion and is very slow.  Will step work?  Can Pro-e produce SAT or x_t?  What settings should I suggest they use for better IGES files?
RE: Translation from Pro-e
What version of Pro/E? In Wildfire you can enable parasolid exports.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
I'm not sure what version they are using.  It's a large aerospace company and I'm down the food chain a bit.  The latest IGES file I got came in with a ton of surfaces untrimmed. I brought this same file into Surfcam with no problems.
I just switched to SE from Cadkey because of these same kind of issues.  I hope I haven't wasted allot of money and time.
Try Step
