Al Heat Shield material
I want to use an aluminum sheet as a heat shield. Standoff will be 2" from exhaust pipe. What material grade is typically used and with what surface finish (i.e. AA3003, mill finish)?
RE: Al Heat Shield material
Aluminium or aluminium alloy could soften with heat radiated from the exhaust pipe and produce part distortion.
Suggest you try the former options first.
