Managing part/assembly/drawing files
My understanding is that when a file has reference, then it saves the "path" to that reference within.
Well, my company has two folders, "Pending" and "Approved". When you first create part/assembly/drawing files, first we save them in pending directory, and then when they are approved, we want to move a set of files (part,assembly&dwg) to approved directory.
My question is that when you move those files all together, does it automatically update the path? Or it would still point the old path? I first thought it doesn't work that way, but it seems though it works 'sometimes'.
Can anybody help me managing files? Please?
Thanks -
Uka
Thanks -
Uka
RE: Managing part/assembly/drawing files
Using SW Explorer is your best bet to keep the relationships intacted.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
1) If you copy the assembly and parts used to a new location, and then doesn't the assembly still point the old path to parts? Or does it update the path to parts that are in new location?
2) If you copy the part and delete the old one, any file that has reference to the old part would loose the path and cannot find the reference, correct? What can I do?
Thank you.
Uka
You can set up search folders to check for components in certain folders in a certain order. Specified search folders are the first place SW looks for referenced documents.
The next folders SW checks are the folders most recently used to open files and references. After that, SW checks the locations as they were saved.
SW checks "relative path" before it checks "absolute path". For instance, if you have an entire assembly saved in "C:\project" and move or copy the entire folder to "D:\project", and you open the assembly from "D:\project", SW will search "D:\project" before it searches "C:\project". Try some experiments and see for yourself.
http://www.EsoxRepublic.com
I think you solved the problem!!
Uka
Yes using SW Explorer it does update the paths. With SW Explorer you can place the assembly in folder and the Parts in another one. That don't have to reside in the same folder. If you use SW to copy the files all files will reside in the same folder.
[quote]2) If you copy the part and delete the old one, any file that has reference to the old part would loose the path and cannot find the reference, correct? What can I do?[quote]
In SW explorer you can do a "find where used" and change all the files that reference that part. It will basically change the location information in the assembly (that references that part) and tell it the new location path for that part.
Best thing to do, is to test it out. Try out a small Sample assembly and parts.
The proper Technique is to use SW Explorer. It's their for your benefit and once you figure it out you won't go back... IMO.
Scott Baugh, CSWP
FAQ731-376
SW Explorer & a PDM Works are the only ways to keep the SW's data healthy. I remember the days before they offered those two tools and it was a nightmare with multiple users. If anybody still thinks that can do data management with these tools is a fool riding the edge of data disaster. That's my 2 cents.....
Vince
