making a 3D pipe construction
I am wanting to design a wakeboard tower (made of aluminum pipe) in mechanical desktop 6 and I am not sure about how to go about drawing it up. I tried using the 3D pipe command but all that gives me is a blue line representation of the pipe. I would like to be able to set the pipe diameter and then view it in 3D so I can get a good idea of what it will look like. Any help in this will be greatly appreciated!!!
RE: making a 3D pipe construction
Good luck
Patrick
In case you didn't notice, on the "3D Pipe Path" dialog box, the last column is "Radius". Just enter the desired radius for each corner that you want a radius.
Flores
