Using simulink to function on a vector
Hi all,
I am a new member, I am trying to use simulink to perform denoising
on a vector signal. I tried to use the wavelet function WDEN (it is
included in the wavelet lib in the toolbox). The output of the s-
function block is the same as the input signal.
I guess the problem is that simulink is processing on the input
vector point by point, but this is not what I need as the denoising
require to have the whole vector then process on it.
If anyone could advice that would be appreciated.
thanks,
Amal
