Fire Suppression (Water Mist) Metalclad M/V Switchgear
Can anyone provide me with information on water mist fire suppression systems. I have previously read an article where water mist jets were installed in the air insulated bus chamber of 11kV S/G for extinguishing fire. I would appreciate any information on this type of system.
RE: Fire Suppression (Water Mist) Metalclad M/V Switchgear
Sounds bogus to me!
"Venditori de oleum-vipera non vigere excordis populi"
I have seen smoke detectors installed directly above, but not water sprinklers.
Of course oil dilled equipment is another issue.
See http://fire.nist.gov/bfrlpubs/fire94/PDF/f94184.pdf
Aside — AFFF has been used in large pulsed-power research facilities, but I've not witnessed related post-discharge mopup.
http://fire.nist.gov/bfrlpubs/fire02/art130.html
And consider the potential of a leak in the misting system while the power was on! I will not entertain the arguments that "it won't leak". That is just a challenge to good 'ole Murphy.
jraef, that is a good point. I'll bet the ‘3-6% additive' does not hasten evaporation, much less decrease conductivity of the medium. Seems kneejerk reaction to Halon [via the Montreal Protcol] tended to promote hasty {but surely politically correct} support of "new and improved."
http://www.reliablefire.com/co2folder/co2systems.html
http://www.fike.com/co2_com_products.html
http://www.fike.com/marine_applications.html
http://www.getzfire.com/Engineered/CarbonDioxideFireSuppression.htm
http://www.nafed.org/library/whyCO2.cfm
etc. for the CO2 based fire extinguishing alternative to water mist
http://www.nafed.org/library/wmist.cfm
for: usage of non-conductive water for the water mist (distilled water)
