Plot Date -(for Steve -3dlogix)
This post is especially for Steve from 3D Logix, but if someone else is interested...
Few months ago, you were asking about an automatic date/time printing method on the paper. I found this link:
http://www.spekan.com/innotiv/index.php?mnu=dwnl&sub=pldate
Spekan has an utility that maybe you can help you. Take a look at it.
-Hora
RE: Plot Date -(for Steve -3dlogix)
Hora, thanks for thinking of me!
I actaully tried (or almost did) their plot date utility, but found it cumbersome with all the local temp settings, since we had different users on different machines.
Since then, I use ProE's print time and adjust the x,y offset of the plot. Works great actually.
If you have tried it, let me now how it turns out.
Thanks.
http://www.sprdesign.com
Hi Steve,
I'm not using Spekan Plot Date program, but here in my department there are some people interested in.
I will check on my side, too. I was thinking of creating a small program using Pro/Toolkit routines that can do what you need. I'll keep you in touch. I see we are in the same area code (514)
-Hora
