Square to round transition
I want to do a square to round transition in sheet metal and be able to unbend into a flat. I have done a model in the sheet metal module, but I can't seem to be able to create the bend, rip,etc. that will allow me to do the unbending after.
If someone can help me with this final step, it be appreciated.
P.S. I am using Pro-E 2001.
RE: Square to round transition
For a sheetmetal shape to flatten, the final or formed geometry must be flat to begin with (regular straight bends not included).
I used to do this for a sheetmetal fabricator of hoppers and funnels. The only solution was to make a blend, but the circle had to be broken in numerous sections, and attached to similar nodes on the previous section.
It's a long process, but works well. If you want, I will email you a model of what I did.
Steve
http://www.sprdesign.com
on a second note, I thought that Pro-E could tell us what are the numerous bend required to be able to get that shape. I am probably expecting to much for Pro-E.
Thank you for your time.
Alain
What you should do is either make these segments offset to each other (usually a little more than the material thickness) or make the corner and then make a cut to remove the convergence.
Steve
