undefined axis-transferred from assy-to sub-can it be fixed in the sub
I have an defined axis in main assy. I have a subassembly in it, and used the same axis to define positions of parts in the subassembly so I could work on it without haveing both assy files open. When I open only the sub assy, I get the undefined axis error. It makes sense, but I'm wondering how to get rid of it in the sub. Can I fix the axis in some way? If I have the main assy open, when I work on the subassy, the error does not come up. Is there a fix for this or am I just whining?
SW2003 sp 5.1
SW2003 sp 5.1
RE: undefined axis-transferred from assy-to sub-can it be fixed in the sub
Once the subassembly axis is made, use it to define the subassembly features.
We design lots of hinges and small mechanisms. I find models are more robust if I copy key datums from upper levels like pivot axes and then refer to those copies (which still reference the higher level) rather than just use the higher level datums in context.
http://www.EsoxRepublic.com
Thanks for the help
