WinCC ocx problem
WinCC ocx problem
WinCC ocx problem
I'm encountering some problems with an ocx (microsoft date & time picker).
I've inserted an ocx (microsoft date & time picker) in my project. Now I've installed a second PC (back-up PC) an made a duplication of my excisting project and installed it on that new PC.
Everything seems to work OK except that one ocx. It keep giving an error code
" Licence information not found. You do not possess a valid license for the design mode. (DT Picker)
Anyone?
RE: WinCC ocx problem
Did you use the Package and Deployment wizard (found in Add-Ins) to make an installation package, or did you just copy the exe file?
The P&DW produces an installation package that manages all dependencies including registering ocx and dll on the target machine. If it's not directly visible in Add-Ins, select the Add-In manager and load it from there.
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
John,
Thanks for the reply.
The solution to my problem was installing Office because I used an OCX of microsoft. As simple as that
