LIMIT TOLERANCES
LIMIT TOLERANCES
Does anyone know if it is possible to show limits on a dimension one above the other rather than in a line as is the default. I can find no options in the drawing set up file or the config.pro. I am using Wildfire.
Thank you
Andrea
Thank you
Andrea
RE: LIMIT TOLERANCES
My guess is that it is in the properties of the dimension.
You may also have to set a .dtl parameter or 2. Maybe even play with edit-setup.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
