Ceiling Incandescent
Hi every ones.
How can I click and drag a ceiling incandescent from the Design content into my drawing? I can do it with Plumbing but not with lighting fixture.
RE: Ceiling Incandescent
 If you are referring to the design center symbols, here's a relatively simple fix until you find a better one :
 * open the design center symbols where your desired
   symbol is found
 * Select Express Tools, Blocks, then Copy Nested Entities
 * Copy and displace the desired symbol
 * Use wblock to place your new symbol
 * Send me a large check for the tip
                                              X
                                             XX
                                            XXX
                                           XXX
                                          XXX
                                         XXX
                                        XXX
                                       XXX
                                      XXX
                           XXX       XXX
                            XXX     XXX
                             XXX   XXX
                              XXX XXX
                                XXX
I can make the check larger if you need it
