SOLIDWORKS HOLE TABLE
HI THERE EVERYONE,
I NEED TO KNOW IF IT IS POSSIBLE TO ADD TOLERANCE DIMENSIONS TO HOLE TABLES AND IN THE BOM'S IN SOLIDWORKS 2004. I HAVE SP3.0 LOADED ALSO. I HAVE BEEN TRYING FOR ABOUT 3 HOURS NOW AND CANNOT SEEM TO FIGURE IT OUT. ANY HELP WITH THIS WOULD BE GREATLY APPRECIATED. THANKS IN ADVANCE.
RE: SOLIDWORKS HOLE TABLE
HELLO AGAIN,
WELL I TALKED WITH OUR SUPPORT TEAM AND THEY SAY IT ISN'T POSSIBLE RIGHT NOW IN SOLIDWORKS. HOWEVER THEY MAY BE ABLE TO INCORPORATE SOMETHING IN THE NEXT RELEASE. I SEEM TO GET THAT ANSWER ALOT FROM SOLIDWORKS. DOES ANYONE KNOW OF A WORK AROUND METHOD FOR APPLYING A BI-LATERAL TOLERANCE DIMENSION TO A TABLE? EXAMPLE (+.0001 -.0000) WHERE THE DIGITS WOULD BE STACKED ONE ON TOP OF THE OTHER. HOPE THIS MAKES SENSE.
